Help!
Can anyone direct me to where I can find a Structural Connections Tag.
Steve
It looks like this user asked the same question some time ago. And on this page someone has created the tag you need.
Lots of Connection tags are in the library under Annotations-->Structural
If you start with an architectural template, they are not loaded by default. You need to start with a structural template instead. Same for MEP.
did your issue is solved? and need any other help?thank you!
Just ran into this problem. Make a structural connection tag by editing the generic family tag, and Save As a structural connection tag. You need to change the Family Category to Structural Connection tag. Do this by clicking on the Family Category and Parameters button, which is part of the Properties group on the left side of the ribbon. Choose Structural Connections.
Also note there is no Structural Connections family template that ships with Revit. I think you would need to start with an existing structural connections family, or do the Save As thing starting with the generic family template.
