no selection for template file available for new project
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
1311 Aufrufe, 4 Antworten
I installed the student version of Revit 2018. When creating a new project, however, I don't have any template files to choose from. I need the architecture template.
Does anyone know the problem and can help me?
Tags (1)
Beschriftungen (1)
4 ANTWORTEN 4
Nachricht 2 von 5
mauricio_mssf
als Antwort auf: Anonymous
There was an error in the installation or you deselected the option to install the Autodesk Content Library, follow the link to download and install the 2018 version, see which unit format and language suits you best.
https://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/autodesk-revi...
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Nachricht 3 von 5
als Antwort auf: mauricio_mssf
Thank you @mauricio_mssf .
I had already found the download page but at first I thought it didn't work. But now I've noticed that I don't have a Program Data folder on my computer that Revit is talking about and that the file is not called Architecture but rather default. But now I have the right template.
Thank you very much.
Nachricht 4 von 5
David_W_Koch
@Anonymous
The ProgramData folder in Windows is a hidden folder.  If you do not have the display of hidden files and folders turned on in File Explorer, you will not see that folder.  You can type paths that include that folder name (note, no space between "Program" and "Data") in the address bar; I find it easier to turn on the display of hidden files and folders.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Nachricht 5 von 5
christodewet
When starting a new project in Revit 2023 I have no Project templates
Tags (1)
