good day, Would like to find out where to get the family or material for paring areas and to build a road on Revit.
Also, need the materials for electrical and plumbing for piping and wiring?
Could you please assist?
Gelöst! Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
Could you clarify if you're looking for the materials or the actual elements? You set up your own materials in the material browser. If you're talking about the elements, you build roads from standard Revit elements - you would need to elaborate to help more. In case of mechanical elements, you can load these as families from the library.
maybe you can refer to this LINK, it could be templates and libraries are not installed and see if helps. thanks
