Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
No "Imperial-Architectural Template" option for New project even though the default path for family template files is English-Imperial
Michael_K_
Message 1 of 16
Michael_K_
My Revit 2021 tutorial is showing me that I need to choose the "Imperial-Architectural Template" from the outset when choosing a New Project. I have downloaded the US English Content for Revit 2022, and none of my options begin with "Imperial..." even though I have set the default path as C:\ProgramData\Autodesk\RVT 2022\Family Templates\English-Imperial
Can someone show why this isn't enough??
Has this detail changed for Revit 2022?
Replies (15)
Message 2 of 16
Project templates and Family templates are different and they are stored in different folders.  What you need is this:
Message 3 of 16
RDAOU
@Michael_K_
Project templates are in a folder called Templates not Family templates
Message 4 of 16
Michael_K_
I still cannot see the right template, screenshot attached
Message 5 of 16
RDAOU
@Michael_K_
It is the default.rte or can also use the commercial.rte
The tutorial you are following must be for an older version where they were named differently
Message 6 of 16
Default.rte is the US Imperial project template.
Message 7 of 16
Michael_K_
Still does not spell out for me that it is imperial in the list.
Message 8 of 16
It doesn't matter.  You can name it whatever you want.
Message 9 of 16
Michael_K_
Can anyone confirm that Revit 2022.1 does not explicitly say Imperial before the template titles...
Message 10 of 16
RDAOU
@Michael_K_
Confirmed ... See GIF below
  • The template Default.rte is the imperial template
  • The name in the drop down menu for New Projects does NOT need to read Imperial (user can edit the name)
  • If you want the name to be listed and EXPLICITLY state Imperial-, you have to rename it under Options >> File Locations >> Name (this would only be useful if you use for example: both metric and imperial)
Message 11 of 16
Michael_K_
Assuming your English Imperial Template folder contents look like my screenshot, then I understand the your gif
Message 12 of 16
RDAOU
@Michael_K_
YES believe me they are the same : o) we have no interest in misleading you
Message 13 of 16
David125
The one in my folder was still metric.
Message 14 of 16
RobDraw
Some more information and a question would be helpful.
Rob
Message 15 of 16
cbalkcom
Community Visitor
Community Visitor
I only have two options when I make a new project (Imperial Multi-Discipline and Metric Multi-Discipline). I need to use Imperial Architecture for a class. Any ideas about how to get this option?
Message 16 of 16
mhiserZFHXS
There are only two OOTB templates now, Imperial and Metric. If your teacher/professor is requiring an architectural template, politely tell them they are out of date.
