I have two detail views which I need to reference to a call out a section plan. I had originally linked them, but I closed Revit and now the callouts have disappeared. I would simply add two callouts again, but now I can't find these details in the drop down box, It's like they don't exist, although as you can see they are in the same file. Any ideas?
Something is wrong, you can reference elevations in a section that shouldn't be possible and then also the reason you can't select callouts??
What can you reference in a Floorplan?, or could you post a empty version of the file?
- Michel
Hi all,
I had multiple files from different projects open but sharing the same screen.
Sorry really rookie, everything has appears as it should now.
Thanks for your help.
There is no detail view in the browser in your second screenshot. It's from a different file.
