Afternoon,
I just installed Revit 2019 in an attempt to import a point cloud in .PTS format. I need to get it over to 3ds Max. This Autodesk page states that you can select .rcp, .rcs, or raw formats. However, in Revit, Under Insert/Link/Point Cloud, the dialog box only allows for the first two file types.
What might I be doing wrong?
John
Gelöst! Gehe zur Lösung
@loboarch I think your help page needs updating.... EDIT: Nevermind, it does say it is for Revit 2015.
@NHHiker , you are not doing anything wrong, that help page was from a few years ago. In Revit 2017 and 2018 I still have the same options as your help page. Revit 2019 is just the two options as Recap 360 gives you a lot more options on importing point files.
Help page is ok. AKN search tends to surface older versions of a particular topic because it has received more traffic. There is a filter for year on the AKN search to help with that issue. The page linked is sourced from the 2015 online help.
http://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-B89AD692-C705-458F-A638-EE7DD83D694C
The current (2019) version of this page is accurate.
http://help.autodesk.com/view/RVT/2019/ENU/?guid=GUID-B89AD692-C705-458F-A638-EE7DD83D694C
Thanks much for the quick feedback and verification. Recap Pro being put into motion right now. Something new to work on today, but I was at least able to import the raw files and see the results so far.
Thanks for the info regarding my version numbers. It kind of threw me that they yanked that option between versions.
BTW, your hotlink for the 2019 page seems to have a couple of extra characters and that's leading to a 404. Copying and pasting got me there.
Cheers.
Cheers.
Forum seems to be mangling the redirect link somehow???? Even tried fixing it by erasing and replacing it again and it still does not work????
