I have Revit LT 2016, and on the component tab there is no model in place option. All I can do is place a component from a family. Does any one know why?
Gelöst! Gehe zur Lösung
Gelöst von loboarch. Gehe zur Lösung
man - this is killing me....there is no way I need full blown Revit but this limitation is a serious drawback and a gigantic pita
If it is a serious drawback and a gigantic pita for you then you may want the full blown Revit? LT also does not have view filters, which may or may not be another drawback for you.
IDK about view filters and if they would be helpful - so far haven't found a need. But I need to make custom countertops and all directions for this refer to model in place --- I cannot figure out how to do it in a another way - someone else answered about this but I am struggling. And why do components like cooktops not sit at countertop height and the symbol not let you adjust it's height in attributes/properties? Arrgghh -- I am wasting so much time.
You asked the same question:
http://forums.autodesk.com/t5/revit-architecture-forum/model-in-place-component/m-p/6568997#M127031
Did the answer not fulfill your need? If not, can you clarify what does't work so that we can go to further details.
You will be able to tell from this where I am struggling - I did finally get the cooktop to sit on the countertop but the other issue is not yet resolved - I will look into it more tomorrow - thx all
