no mass shape options preview, bug?
15 ANTWORTEN 15
GELÖST
Nachricht 1 von 16
miguelnaranjo
2506 Aufrufe, 15 Antworten
hello, from some months ago, when I work in masses, I don´t see the shapes preview window where you choose the kind of shape to generate, plane, extrusion, sphere...
is in revit 2021.1.16
I didn´t find option to manually deactivate that, so maybe it is a bug?
if someone know the soltion, I will appreciate
15 ANTWORTEN 15
Nachricht 2 von 16
ennujozlagam
als Antwort auf: miguelnaranjo
maybe file is corrupted. you can try this file from revit 2021? thanks
Nachricht 3 von 16
miguelnaranjo
als Antwort auf: ennujozlagam
sorry, I forgot to be more explicit
in exterior masses works fine
the problem only happens in in-place mass
Nachricht 4 von 16
ennujozlagam
repair your program or do a clean uninstall and reinstall again. it could be some files are corrupted. thanks
Nachricht 5 von 16
The preview maybe on a different monitor.
Nachricht 6 von 16
Happens to me from time to time.  No biggie though.  Zoom to Fit and restart Create Form usually does the trick.
Nachricht 7 von 16
miguelnaranjo
als Antwort auf: ToanDN
no, that is the problem, maybe is shown out of the range of the screen, because I can accept the default option, but not choose
Nachricht 8 von 16
Not every form creation has 2 options.  Sounds like you are saying the Revit is just creating a 3D form without giving you the choice to pick between options (e.g. Extrusion, Surface, Sphere). Is that right?  If Revit is proceeding without your input, then there are no other options available.  If there were, then Revit wouldn't be able to proceed and make the form without your selection.
Nachricht 9 von 16
miguelnaranjo
als Antwort auf: barthbradley
no, for example also when can do prism or face (only do prism) or sphere/cylinder (only do cylinder)
I put you pictures before and after with just a circle, NO options to Choose
I know reinstalling is an option, but we are always very busy and in the middle of a big project
Nachricht 10 von 16
Have you looked at the other screen?  As I showed you earlier, the option is not in the same Revit screen.
Nachricht 11 von 16
miguelnaranjo
Yes, even I connected a second monitor to see if appears, but not
Nachricht 12 von 16
octopinegees
In the case of the circle, making sure that it is not a reference line usually does the trick. And zooming out to the default view distance should allow you to see the form selection menu if that isn't showing up normally.
Nachricht 13 von 16
Moshari112233
The trick that I use is that:
Zoom out in your canvas to make a larger space, draw a big circle on the canvas then pick the “create form” 9 out of 10 you will get the options that we should every time expect to get, choose the one you want and make the circle into a sphere. Now you can go and choose your preferred object and pick “create form” again, this time the options you were looking for are available to implement.
I hope it did work.
Nachricht 14 von 16
costelos
use SpaceBar to cycle between the two options!
Nachricht 15 von 16
dinakh104
als Antwort auf: costelos
thank youuuuu
Nachricht 16 von 16
npeJCMF5
Thank you, worked like a charm.
