No IFC file after exporting to IFC from Revit
2 ANTWORTEN 2
Nachricht 1 von 3
413 Aufrufe, 2 Antworten
Hi all,
I tried to search in the forums but couldn't find the answer.
I am trying to export one tower to ifc. It processes for a while and then stops (indicating that it's done). However, when I go to the file location I specified, I couldn't see any ifc file.
-I tried to create a new file with box walls and exported it with the same settings and it went fine.
-I tried to export the 2 files together and only the dummy file got exported.
-I tried to use a different PC but I get the same issue
-I tried to uninstall the IFC Exporter plugin but got another issue instead (after clicking Export to IFC, everything just becomes unclickable & I will have to close Revit & will be unable to save).
-I tried to play with the Quality setting, export settings, etc
I uploaded my journal file.
Thanks a lot.
Tags (1)
2 ANTWORTEN 2
Nachricht 2 von 3
nmarcelis
als Antwort auf: Anonymous
What addin did you uninstall?
There's an IFC exported built in into Revit.
You can find more information about the workflow here.
Revit can sometimes 'hang' when exporting an IFC.
If this helped you please accept this answer as a solution.
Revit Certified Professional Architecture, Structure and MEP.
Nachricht 3 von 3
als Antwort auf: nmarcelis
Go to Export=>Options=>IFC Options and verify that the correct Standards are loaded.
