Hi I am working in Revit 2021 I want to create a curtain wall
When I check the wall types there are no curtain walls to choose from.
is that the way it supposed to be in Revit 2021?
How do I create one were can I get them from?
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
You need to download the content as a separate transaction. Template Content has predefined CW Wall Types in it.
..or you can just start from scratch and create your own.
I have them loaded in I see them in the families but when I start the wall command they don't show up in the wall types
See pic attached this is what I get when I stat the wall command in the other versions in my 2021 I don't get that only all the other wall types
so what are the 3 curtain wall types in the families loaded into the template?
see attached pic
@Anonymous wrote:See pic attached this is what I get when I stat the wall command in the other versions in my 2021 I don't get that only all the other wall types
Sounds like you don't have any of these Curtain Wall in another PROJECT you are working in. Use Transfer Project Standards to transfer content from one Project to another.
As I said in my first reply, a few Curtain Wall Types are included in all the default Project Templates that come with Revit.
@Anonymous wrote:so what are the 3 curtain wall types in the families loaded into the template?
see attached pic
You win. I'm terribly confused now.
Please restate what the issue is.
I don't understand what you are saying
did you see the picture I attached ?
when I open the families I see the 3 curtain wall types from there if I right click on one of them I can select create instance. but that's just a work around. I want it to show up in the wall types drop down when I start the wall command like it usually does.
why is that not happening don't you usually get to chose a curtain wall in the wall types dropdown when you start a wall command?
Does it work if you drag a Curtain Wall type from the project browser onto your floor plan or 3D view? It is to make sure if the types are not corrupted.
What is so hard about understanding and doing this?
You sure about that? Not showing up in Preview Selector? Scroll all the way down in the drop box.
Go to Architectural Tab=>Wall:Architectural. Select a Wall TYPE from the Preview Selector drop down on the Properties Pallet. Scroll to the bottom. See Curtain Walls? Pick one. Can you use it now?
Out of curiosity, if you select a Curtain Wall instance already placed in the Project, does the Preview Selector show a picture of it? If you click on the "picture" does the Drop down box activate? Do you see other Wall and Curtain Wall Types once it is expanded?
I have 3 screens 1 is set to scale 175% and the other 2 are 100%
yup I scrolled down until the bottom its not showing any curtain walls
Try set them all to the same %, 100% is the safest. if that works then gradually increase to 150% max.
It is important that all your monitors share the same Display Scaling % to get the Revit interface work without hiccups.
Yes Now I see it
does that mean something is wrong with my program or that happens?
Now its there without changing the scale
after I dragged them in I shut the program and now its there.
does it have to do with something wrong with the program.
