Why the heck cant i get pretty clouds in my rendering?
I feel OK with my model and have a start on site, ( I know-no plantings), but why the heck are no "Few Clouds" showing? Please.
I can always use an image. Find something on-line you like and use that instead of Revit stock.
you can download some clouds HERE and HERE set your background image in rendering. thanks
… hi @glkirk
… sometimes it is frustrating to get the perfect rendering shot
… but if you want to show a few clouds you cannot render in that angle
… (based on your picture) you are pointing to the soil/earth
… that is why your image is not showing “few clouds”
… you will need to change your angle a little bit to point to the sky
… or at least to the horizon
… change the angle of the image
… or as mentioned by @barthbradley and @ennujozlagam
… you can use any background you like
… and you will probably get a better end result
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
