No 1st plan view is showing in the project.
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
1836 Aufrufe, 7 Antworten
There is no 1st floor  (actually it is but not) Let me explain: In the 1st floor plan I can only see the names of everything. I cannot see the walls and all families that I can see in a 3d view.
7 ANTWORTEN 7
Nachricht 2 von 8
aRcHiTeCt.JM
als Antwort auf: Anonymous
… hi @Anonymous
*** upload your file
… there could be a lot of issues
… could be that you don’t have drawn walls
… that the height of your floor is in a different level
… that your visibility graphics is off for those elements
… that you are opening a different plan layout
… that your template properties are set to not show that
… or you can delete that first floor plan and create a new one
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Nachricht 3 von 8
ennujozlagam
Try to check your phasing. Thanks
Nachricht 4 von 8
@Anonymous :  Here's a great reference to keep handy for occasions just like this.  Keep a hardcopy of it within reach. You'll use it a lot as you learn Revit.
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
Nachricht 5 von 8
als Antwort auf: aRcHiTeCt.JM
Hello. I don’t know what are you saying. Here is the file. https://filebin.net/1w9ez8e0h7jozizv/Ro0m.7z?t=of7yjz5l
Nachricht 6 von 8
aRcHiTeCt.JM
… hi @Anonymous
… go to your first-floor plan
… click on close reveal hidden elements
… right click on the red box/elements
… and chose unhide in view elements (it will turn red)
… then click again the close reveal hidden elements button
… now is unhidden
aRcHiTeCt.JM
REVIT EXPERT ELITE
Nachricht 7 von 8
How can I delete a floor plan and recreate it?
I mean I know how to delete it, but how to create a deleted one?
Nachricht 8 von 8
aRcHiTeCt.JM
... hi @Anonymous
... recreating a plan view after it has been deleted
... If a floor or ceiling plan view has been deleted from your project browser, but the level line still exists, then you can recreate the view. Follow these steps:
  1. Click View menu > New > Floor Plan (or Ceiling Plan).
  2. *** un-check ... "do not duplicate existing views"
  3. Select the level under Floor Plan views to create the new floor plan.
  4. Click OK.
aRcHiTeCt.JM
REVIT EXPERT ELITE
