Newcomer
7 ANTWORTEN 7
Nachricht 1 von 8
Fab.Spaeder
341 Aufrufe, 7 Antworten
Newcomer
I'm not sure, wether I'm right in this forum but I have a simple question only: Is it normal that the student version of REVIT 2022.1 needs about 6.5 minutes to start up? I run analyzed the Journal File.
7 ANTWORTEN 7
Nachricht 2 von 8
ennujozlagam
als Antwort auf: Fab.Spaeder
you can refer here and see if helps. thanks
https://knowledge.autodesk.com/support/revit/troubleshooting/caas/sfdcarticles/sfdcarticles/Revit-is...
Nachricht 3 von 8
Fab.Spaeder
als Antwort auf: ennujozlagam
Thank you, ennujozlagam, for your quick reply!
However, I'd like firstly just to know wether the duration of the start up is comparativley normal or abnormal.
Nachricht 4 von 8
ennujozlagam
i think i'ts normal try to install latest updates from autodesk and see if helps. thanks
Nachricht 5 von 8
RobDraw
Not normal.
Rob
Nachricht 6 von 8
luisPDAN6
What are the computer specs? How much memory do you have on that computer? Are you drives HDD or SSDs?
Nachricht 7 von 8
Fab.Spaeder
als Antwort auf: luisPDAN6
DELL PC precision 7520 (8.2017)
Intel core I5-7300HQ 7th generatio 2,5GHz
memory 32GB
64bit
1TB  SATA HD, MPWS
WIN 10 Pro
Nachricht 8 von 8
If it took longer to start than it took you to read and reply to @ennujozlagam's post, then it took too long.
  Slow start up in Revit | Revit | Autodesk Knowledge Network
