Newbie Brain Fry
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
payingtoomuch
237 Aufrufe, 3 Antworten
Newbie Brain Fry
I've been working diligently to clean up a template setting up vg etc.
Had this brilliant idea that I would delete everything in the model and recreate all the different template type views that I had started setting up in a dumbed down version of the original template.
I recognized that this would delete all my views.
So, now I'm standing here trying to figure out how I can view all my levels in my model and reference them in both section, elevation and plan..... now that I don't have any plans to work from.
Note that I know the levels are still there because they show up when I select wall tool and in properties the top and base constraints show up.
I was able to draw a rectangle of walls in 3D but still don't have any plans.
Created a work plan and was able to draw a floor attached to the walls.... but still don't have a plan.
Looking like I can't do anything without a plan or a section and I can't get a section without a plan.
I think if I can simply get one plan view going I'll be able to sort the rest out.
Any ideas?
3 ANTWORTEN 3
Nachricht 2 von 4
Prvoime
als Antwort auf: payingtoomuch
View - Plan views - Floor plans.
This what you're after?
https://help.autodesk.com/view/RVT/2020/ENU/?contextId=HFloorPlan
Nachricht 3 von 4
Go to View Tab=>Plan Views=>Floor Plans and recreate Level 1.
Nachricht 4 von 4
payingtoomuch
Unbelievable. I've been staring at this screen way too long!
Was on another planet somewhere.
Thanks.
