{NEWBE}Structural beams are not visible
1 ANTWORT 1
Nachricht 1 von 2
1611 Aufrufe, 1 Antwort
 I am putting structural beams in my basement ceiling plan.  I am putting them on top of columns that are drawn in basement plan.  When I go to draw the said beams in basement ceiling view, I get a notice saying "None of the created elements are visible in Floor Plan: Basement Cieling View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings."
      Looking for suggestions.  Constraints =Firstfloor.  Tried changing constraints did nothing
1 ANTWORT 1
Nachricht 2 von 2
cbcarch
als Antwort auf: Anonymous
Type VG and make sure Structural Framing is turned on under Model Categories.
Your View Range is probably not set to display the beams, as they are located toward the ceiling.
You should use a new Structural Framing View to place the beams, which will display them while placing them and afterwards for dimensioning/annotation, etc.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
