Hello all, I am new to Revit and I'm using LT if that makes a difference. I'm trying to figure out how this works and I really need good tutorials for starting residential plans. I'm typically draw 2d plans with elevations and bought this to speed me up but I'm backing up bad trying to figure this out. I don't want to waste time watching unnecessary tutorials I just need to create my topos, floors, walls, stories like basement and upstairs, ceilings, roofs and then dimensions, hatches for exteriors, elevation views, put it all on title blocks and print! Don't care about MEP, squares of shingles, linear ft of fascia, etc. I also apparently need to build libraries for everything, ugh! Walls, doors, etc. Most everything I use is not existing. Does anyone have these in a file I can download? Sorry to sound so desperate but I'm really getting behind. Any help towards the right tutorials and/or videos would be appreciated. Can't find online classes either. Thanks
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
@Anonymous wrote:I don't want to waste time watching unnecessary tutorials I just need to create my topos, floors, walls, stories like basement and upstairs, ceilings, roofs and then dimensions, hatches for exteriors, elevation views, put it all on title blocks and print!
Hire a learned professional who has created topos, floors, walls, stories like basement and upstairs, ceilings, roofs and then dimensions, hatches for exteriors, elevation views, put it all on title blocks and printed it. Be a heck of a lot faster.
Recommended Reading:
Residential Design Using Autodesk Revit 2020
Residential Design Using Autodesk Revit 2020 is designed for users completely new to Autodesk Revit. This text takes a project based approach to learning Autodesk Revit s architectural tools in which you develop a single family residence all the way to photorealistic renderings like the one on the cover. Each book also includes access to extensive video training designed to further help you master Autodesk Revit.
The lessons begin with a basic introduction to Autodesk Revit 2020. The first four chapters are intended to get you familiar with the user interface and many of the common menus and tools.
Throughout the rest of the book a residential building is created and most of Autodesk Revit s tools and features are covered in greater detail. Using step-by-step tutorial lessons, the residential project is followed through to create elevations, sections, floor plans, renderings, construction sets, etc.
https://www.amazon.com/Residential-Design-Using-Autodesk-Revit/dp/163057256X
Estimated time to complete course: 12 weeks.
Cost: Priceless.
