New level creation not seen in project navigator
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
jsWVQ7U
350 Aufrufe, 9 Antworten
I created a new level in an elevation using Level (LL) and it shows in a vertical view, but it doesn't show up in the project navigator side window. Any help is welcomed. Thank you!
9 ANTWORTEN 9
Nachricht 2 von 10
vitorbortoncello
als Antwort auf: jsWVQ7U
You need to create the view:
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 10
RC_RVT
Make sure that the button to "Make Plan View" is ticked when you draw your new level.
If this works, please mark it as an accepted solution. This helps make the forum a better place.
Nachricht 4 von 10
jsWVQ7U
als Antwort auf: RC_RVT
Thank you much for your instruction!
However, I'm a beginner. Would you mind indicating where can I find that button "Make Plan View" please? Also, the version that AutoDesk downloaded is in Portuguese as I'm in Brazil. That causes more confusion because sometimes the terminology used in English is not a direct translation into Portuguese...
Nachricht 5 von 10
RC_RVT
Hi @jsWVQ7U see below screenshot, I have put a red box around the tick box you need to tick.
Nachricht 6 von 10
hubbardFJXGT
Also you have "Do not duplicate existing views" checked in your create plan views dialog. Uncheck that or choose/create a new view type.
Nachricht 7 von 10
jsWVQ7U
Thank you much! This solution solved my problem! Thank you!
Nachricht 8 von 10
jsWVQ7U
als Antwort auf: vitorbortoncello
Thank you much indeed! It worked!
Nachricht 9 von 10
jsWVQ7U
Thak you much indeed! It worked!
Nachricht 10 von 10
jsWVQ7U
Thank you! It worked!
