New IFC versions in Revit.
1 ANTWORT 1
Nachricht 1 von 2
550 Aufrufe, 1 Antwort
Hello All,
I have been using Revit 2014 from a some time now.
Recently I started using Revit 2017 version.
Unlike before there are different IFC options available now. Mainly IFC4 and IFC2x3.
What is the difference in the IFC files created in this versions?
I found that it is possible to bring some of the shared parameters available in IFC files.
I tried creating IFC files using both the options. But some of the models were not visible in IFC file created using IFC4.
Does anyone have any idea about the use and application of different IFC versions available in Revit 2016 and 2017?
1 ANTWORT 1
Nachricht 2 von 2
loboarch
als Antwort auf: Anonymous
I am not an IFC expert so I can't say specifically the changes. The BuildingSMART group is who makes the IFC specifications we follow. You can check their website for IFC file format history and the changes made by each.
http://www.buildingsmart-tech.org/specifications/ifc-releases
Jeff Hanson
Principal Content Experience Designer
Revit Help |
