New here! Question about curtain walls and them overlapping..
3 REPLIES 3
550 Views, 3 Replies
Hi there!
I'm very new at this. I'm drawing a building and I'm placing curtains walls here and there. But as you can see on the picture, they are overlapping, even if they both are drawn from the same basepoint.
How do I fix this? Please see attached screenshot.
Please help, I appreciate it very much!
Tags (2)
Labels (2)
3 REPLIES 3
chadwickt
Hey there! It looks like your walls are flipped the wrong way. Select them, then the flip arrows so that the walls go to the outside of the center line. While drawing them, you can press the Tab key to flip them. This will leave a gap at the corners, but that will be filled when the corner mullion is placed.
Define and use an "L Cornet Mullion" as shown:
in reply to: chadwickt
Thank you so much!
