Net Living Area Calculation
2 ANTWORTEN 2
Nachricht 1 von 3
586 Aufrufe, 2 Antworten
Hello All, for a project we have to calculate the net living area of each unit, which is the unit net area minus interior walls and shaft areas. We are trying to strategize and see if we have to use rooms or areas for this purpose. The main challenge is you cannot set your walls to be room bounding (which you need to exclude the wall area) but let the unit area/room extend beyond that wall - see the screenshot below, we are trying to calculate the area as shown in the right plan.
Anyone has a similar experience or solution that can share? Many thanks in advance.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
What about Spaces and Zones instead of Rooms and Areas?
 Revit OpEd: Spaces instead of Areas
Nachricht 3 von 3
cbcarch
You could try using Area Boundary Lines and draw them precisely around the walls an shafts, then use Areas to display the NLA.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
