I’ve nested the letters Dp within a down pipe family, but depending on the wall I host it on, the Dp text displays incorrectly.
I’m well aware that in order for this to work, I need to nest 4x individual generic annotations within the down pipe family, and then rotate them individually to display corporeally.
To add to the complexity of the family, I would also like to control where I can potion the Dp text once imported in the project. In order for this to happen, I added shape handles to each nested Dp text, however what I've noticed is that even though the other Dp texts are switched off (using a yes/no parameter) I still see the shape handles.
Any way around this issue?
I did try adding the yes/no parameter to the Reference Lines that control the shape handles, but unfortunately that made no difference 😞
File attached....
