I have a window family with multiple nested window families within it. I call this a "Grouped Window"
When I load this grouped window into a project, I can either Tag the entire group, or the nest windows. When I tag the nested windows, the width and height come through correctly, but the sill height is not correct. If however, I tad the whole group, the sill height is correct. Any ideas on how to get the nested families' sill height to match the host window's sill height? I've been going nuts trying to figure this out.
I'm trying to avoid creating a new parameter for the sill height because that would mean I need to change my window tag family to read a new parameter, then I'd also need to change my schedules to schedule the new parameter, then I would also have to add the parameter to my other window families that currently work fine, other wise their sill heights won't show up in the newly adjusted tags and schedule. Any help or direction here would be greatly appreciated!
I've attached the offending family
Please see this video for the issue:
https://www.loom.com/share/606509756a894bd9867a02498bac8b7f
Solved by ToanDN. Go to Solution.
Solved by brenTRONwiberg. Go to Solution.
Solved by barthbradley. Go to Solution.
Make the Ref. Plane located at the Sill in the Family the "Origin" Ref. Plane.
...this is what you want; right?
@brenTRONwiberg wrote:
This is close. So I did already set the sill reference plane to "Defines Origin" (I forgot to upload that version) and this makes the group of windows show the correct sill height as you have shown here, but the issue is that the nested windows don't show the correct sill height. It's infuriating. I've tried everything I can think of to get those to report correctly, but with no luck.
So for example, if you tab select one of those windows rather than the whole group, the sill height will not be correct. Likely it will read 0'-0"
So, what you are saying is that you have a Window Assembly/Combo Family with Nested Window Sills at different Heights? Windows above Windows? If so, forget reporting Sill Height using the in-built "Sill Height" Parameter. Not sure why it would be documented that way if it's a prefab assembly.
Currently this works great, as the tags and the schedule all report the nested window's width and height just fine. It's only the sill height that is messed up.
I'm not getting how it's "messed" up. Looks fine on my end and in that screenshot I posted. No? All I did was indicate an Origin Ref. Plane in the Family - as shown in second screenshot.
The screen shot you sent is almost what I'm talking about, but not quite. Did you watch the video I shared? It shows exactly the problem. The family shows the correct sill height when you click on it, but when you tab to the nested family it does not.
I just saw your video. Missed it originally, but you are doing what I suspected. Tagging the SHARED FAMILY. It's reporting the Sill Height correctly - albeit not in relationship to the Project which is what you want. So, the in-built "Sill" Parameter is of no value in this scenario. If it makes you feel any better, it's been on the "wish list" repeatedly for years.
....why not forgot the combo (nested windows) and instead, make the trim and mulling parametric? It can be done.
Why don't you tag the nested windows without Sill Height and tag the parent frame with Sill Height. It is quite redundant to show three same sill heights for three windows in a group.
Yes, that is what I did to get by, but then the schedule isn't working right.
This is like a game of wack-a-mole: I work around one issue and another pops up. Eventually I just get exhausted and give up. I curse Autodesk for spending huge amounts of money on unnecessary rebranding evey year while ignoring these bugs and other much needed features.
