Nested generic annotation associated to fixture type
18 ANTWORTEN 18
Nachricht 1 von 19
alexanderA7AF8
1183 Aufrufe, 18 Antworten
We have a lighting fixture family that we use nested generic annotation to tag the fixtures in RCPs, but only seem to be able to make it text field that must be manually updated.  For example, if the Family "Recessed Downright" is placed in the model and is duplicated from Type-A to create Type-B, a Lighting Fixture Tag family will update to the new type, but the nested annotation will still say Type-A.  It looks like only generic annotation can be nested, not Lighting Fixture Tags, so is there a way to set up a shared parameter so that the nested annotation updates when we duplicate a fixture?
18 ANTWORTEN 18
Nachricht 2 von 19
hmunsell
als Antwort auf: alexanderA7AF8
don't understand why you are nesting a Generic Annotation to tag a light fixture. we use a Detail item in our lights to show symbolically in a plan (rectangle with a angular line thru it). our lighting fixture tags read the Type Mark.
  • if you edit type for the fixture
  • Duplicate and rename the Type (we name the types with the Fixture type name)
  • edit the Type Mark for that fixture type.
  • set your Fixture tag to read the Type Mark
Howard Munsell
Nachricht 3 von 19
Is the Tag reading a Type or Instance Shared Parameter value?
...let's clarify: what do you mean by "updating". Updating how?
Nachricht 4 von 19
alexanderA7AF8
als Antwort auf: hmunsell
We originally used Type Mark, but we have the same issue where it would need to be manually updated when you duplicate to create a new type.  In your list below, our hope was to skip the step "edit the Type Mark for that fixture type."  so the nested annotation automatically display the duplicated Type.
Nachricht 5 von 19
alexanderA7AF8
als Antwort auf: barthbradley
Played around with both Type and Instance, we were able to get the Instance parameters to show up in schedules the way we like, but they're still generic annotation that needs to be manually inputted.  By update, I mean it would be nice when I create a new Type, the nested annotation will display the new Type, and not a parameter text field that I need to fill in.
Nachricht 6 von 19
hmunsell
have you considered using the Type Name in the tag? that way when you make a new Type (and name it appropriately) the tag will just use the fixture type name.
Howard Munsell
Nachricht 7 von 19
Yeah, I'm not following. Tags can read whatever Shared Parameters you like. You can even create Calculated Labels in a Tags.
Nachricht 8 von 19
alexanderA7AF8
Is this done in the nested generic annotation family "Edit label" or in the fixture family?  I do not see it as an option when I try to define the label.
Nachricht 9 von 19
alexanderA7AF8
Then I must be missing a step.  I would like the nested annotation to read the Type Name, but can't seem to find that as an option.  Thanks,
Nachricht 10 von 19
hmunsell
  • select the light fixture
  • Edit Type
  • Duplicate
  • name it to the fixture type name you want displayed
  • set the Lighting Fixture tag to display the Type Name
Howard Munsell
Nachricht 11 von 19
"Type Name" is a build-in System Parameter/Label available to all Tags.
Nachricht 12 von 19
hmunsell
https://autode.sk/2yRgPJ9
Howard Munsell
Nachricht 13 von 19
alexanderA7AF8
So starting with the Multi-Category Tag has the Type Name, but I get an error message that only Generic Annotations can be nested.  With Generic Annotation, the "Select available fields from" is blank, and Type Name is not the list when you go to add a parameter.
Nachricht 14 von 19
Generic Annotation???
Labels are what you use.
Nachricht 15 von 19
alexanderA7AF8
If I understand correctly, to nest a label it needs to come from a loaded annotation family, I do not see the option to add a label directly into the family.
Nachricht 16 von 19
Are you in a Tag Family? Do you see "Label" on the Create Tab?
Nachricht 17 von 19
It is possible that when you said "Tag" you didn't mean "Tag".
https://knowledge.autodesk.com/support/revit-lt/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Revi...
...so, how do you "tag the fixtures in RCPs" ?
Nachricht 18 von 19
alexanderA7AF8
Yes, but I can't load a Multi-Category Tag into a family.  Looking at the thread below it seems like this can't be done:
https://forums.autodesk.com/t5/revit-architecture-forum/family-add-dynamic-label/td-p/4750727
We would like to keep our nested annotation, but want to understand the limitations.   Yes, we have fixture annotation tags when you are working in the project, but the hope was to have built in annotation in the family.
Nachricht 19 von 19
