Nested Family visibility issue
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
camirozario
413 Aufrufe, 7 Antworten
I am trying to set the visibility of my anchor bolt. I have assigned the vibility setting with a type parameter, however even if the box is unchecked I can still see my element. I have also tried to insert my family in a project and the visibility setting still doesn´t work
Camilla
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: camirozario
Turn on Visibility Preview in the Family.
....why it doesn't work in Project, I can only guess.  Post the file so we don't have to guess.
Nachricht 3 von 8
Are you saying the Anchor Bolt Family is Nested into another Family and in that Parent Family you have Associated the "Visibility" Parameter, under the Anchor Bolt Properties, to a Parent Family Yes/No Type Parameter?
Nachricht 4 von 8
camirozario
als Antwort auf: barthbradley
Yes that is exacly it! I will attach my family here
Nachricht 5 von 8
camirozario
I really didn't know about this.
I have had a similar issue before and so cool to know that I can activate it.
However in this case it seems to be a deeper issue and the solution didn't work in this case :enttäuschtes_Gesicht:
Nachricht 6 von 8
Mike.FORM
Not exactly sure why the visibility yes/no is not working for the family itself, but if you edit the bolt family and add a parameter to the modeled elements making up the bolt for visibility and then link it to the visibility parameter in the host family it works.
Nachricht 7 von 8
Change the nested families to not shared.
Nachricht 8 von 8
als Antwort auf: Mike.FORM
Go into the RW_Chumbador Family and Associate the 3 Nested/Shared Family's "Visibilty" Parameter (the in-built one under the Nested Family's Instance Properties) to a Yes/No  Parameter in the RW_Chumbador Family.  Then reload he RW_Chumbador Family into the RW_chapaBasePilar Host Family and Associate the Yes/No Parameter(named "Visibility" in Screenshot) to the Visibilidade Chumbador Parameter.
Chumbador1.png`
