Hello everyone,
I have a problem with a nested family. When i load my main family which contains other families, nested one-s also pops out at Project Browser, Families section. I am new here so if you can help that woould be great. I am sorry if it is a newbie question but i checked and saw nothing about this issue.
Thanks in advance.
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
Gelöst von AGGilliam. Gehe zur Lösung
If you don't want the nested families to be listed separately in the project; open that family and uncheck the shared parameter, load it back into the host family, then load the host family back into the project.
The nested family is set as shared. You have to edit the family and then open the nested family. Check off the Shared. Save it as different name. Then load the nested into the family. Replace the shared with new saved family. Purge it and then load it back into the project.
