hi everyone, i have a door family and inside it there is a nested threshold family (i can see it in the project browser) but the problem is that the threshold family is not visible in any view of the door family, but when i load the door family into a project it appears and i dont understand why.
The threshold family is a generìc model and i already checked the visibility graphics inside the door family. Can someone explain me how to show the nested threshold family inside the hosted door family?
Gelöst! Gehe zur Lösung
Gelöst von kostask_oionei. Gehe zur Lösung
The "Soglia Spessore" parameter has its thickness set to 0 in some types, and that hides it.
Is that the issue?
No the issue is that i can't see the threshold inside the door family editor
Inside the door family editor -> Tab Create -> Family Types change the Soglia Spessore or the Thickness parameter.
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
I think that is what @blank... was trying to tell you. But @kostask_oionei made it clear with some screenshots.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
@ralphdenhaan wrote:Hi,
Yup.
Either switch to type which doesn't have that parameter set to zero (in family editor), or set it to something other than zero.
