Nested family material association not working?
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
nathaniel.mcmahon
880 Aufrufe, 2 Antworten
I've created a family from three window families but am having difficulties Getting one of them to received materials defined by the main family. Lots of head scratching.
Is it possibly an issue with the window in question being the nest for the other two windows?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: nathaniel.mcmahon
Because you Painted it. Remove Paint or Paint with a Parameter (e.g. "Material Name (param)").
If you aren't familiar with how to Paint with a Material Parameter, then here's information about the procedure:
 https://bimchapters.blogspot.com/2017/03/revit-materials-painting-material.html
Nachricht 3 von 3
nathaniel.mcmahon
als Antwort auf: barthbradley
Interesting. Not used the paint material function before so I guess the family came with the faces painted already. Strangely I couldn't remove paint from them but I could add my frame material parameter by painting and all is good now. Thanks
