hello, i could really use someone's help as i am modeling a new project containing families and subfamilies that i would want to show in schedules. My families are all shared just as my parameters in the mother family and child families, yet every time i want to make parameters of the child family show in schedules the parameters are automatically set next to the mother family.
Yet in the same schedule with the same families same parameters are showing correctly. I cannot find what i'm missing here.
Also the dimensions shown in the schedule are reporting to the child family original parameters not what they actually are in the project. ( Please note that at first i forgot to make my parameters shared in the child family so i kept those parameters and added shared reporting parameters as shown in PIC 3 )
Appreciate your help.
Are the Parameter Fields that are in the Parent Family also in the Shared, Nested Families? Doesn't look like it.
...are we talking Shared Parameters here? If so, then all the Shared Parameters must be pulled from the EXACT SAME Shared Parameter Text File.
...I don't know if I'm reading you right. Might be easier to understand if you post the RVT.
@barthbradley Thanks for your help, here is the revit project file including the families im working with, the parameters are added in both parent and nested families, but still showing data only from nested families.
Thank you in advance. PS: Im working with the vertical GRC as a test.
