So here's a door family that has a nested Panick bar(generic family). The length of the Bar is controlled with the formula (Width -300mm). It all works, flexes perfectly until I load the door in a project.
For some reason, the flexing is not consistent. Can someone point where I am going wrong?
Cheers!
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
You are currently locking the PB geometry to the side using a dimension...You need to lock it to ref. plane of the door. ie:
Download and Try the attached revised family.
See GIF below
Wow. That worked like a charm. I have been trying to get my head around all the things you changed. And I managed to get it to Flex properly!
Is there a reason you made the PB length as a type parameter? (It was Instance before so I could snap the lengths in host family)
Is it really crucial to set the type of a reference plane? (like right, left, etc?)
thanks again! ![]()
No it is not, but you need to be consistent with the way you constrain nested elements
Ok, So it worked perfectly with flexing until I tried to give the combine the handle bar options.
here's the updated family. I added the ref planes as you suggested. no Snap-locking for length.
Do you where I am going wrong?
Funny enough for me it happens only on the "Bandseite" where I placed the family with a flip.
