Hello all,
I am needing help with a custom stair. Attached you will see the 3D model of the stair. I couldn't find a way to modeled it using the stair tools and then I create a Generic Model. The problem is that I cannot insert a railing or use the Annotation tools intended for the stairs because it is not a stair per se.
Any help will be really appreciated.
Thanks in advance and,
Best regards.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Save off customizing until the stairs are finalized. Use the stock stairs in the mean time. When all the dimensions are finalized, use the stock stairs as a guide to model your In-Place Component Stairs and then hide the stock stairs in the Views and keep the Railing visible.
