Need wall insulation on window reveal
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
420 Aufrufe, 1 Antwort
Hi!
in our standard windows the insulation is extended into the reveal as shown in the red box.. how can I do that?
Thanks!
Tags (1)
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
Open the Window Family, delete the Opening Void and replace it with a Void Extrusion drawn in Plan View,  You can draw a non-rectangular sketch boundary that way so the Void won't cut that portion of the Wall.  You can make the Void Cut fully parametric as well.
..actually, I may have misunderstood you. I think you may be referring to Wall Closure/Wall Wrapping at Inserts.
Revit Wall Wrap Closure - A How To Guide | Revit Products | Autodesk Knowledge Network
Revit Wall Closers – Layer Wrapping at Wall Inserts & Ends – 8020 BIM
"Wall Closure" is a Reference Plane Properties.  Wall Wrapping is a Wall Property.
