Need to turn off back edge lines in 3d view
9 ANTWORTEN 9
Nachricht 1 von 10
spds.desk8
996 Aufrufe, 9 Antworten
In one 3d view , back edge lines are visible. but both view have same VG and GD settings. Please suggest solutions
9 ANTWORTEN 9
Nachricht 2 von 10
RDAOU
als Antwort auf: spds.desk8
@spds.desk8
Delete and recreate view ...what happens?
Nachricht 3 von 10
the left screenshot looks like a 3D View gone wrong.  Happens to us from time to time.  We just write it off as a corrupted view and redo.
Nachricht 4 von 10
RSomppi
Wire Frame vs. Hidden Line?
Easy Test - Create a view template that controls everything from one of the views and apply it to the other. Does it change?
Nachricht 5 von 10
spds.desk8
als Antwort auf: RDAOU
i have tried but its not working.
Nachricht 6 von 10
Try Disabling Hardware Acceleration.
 Hardware Acceleration | Revit | Autodesk Knowledge Network
Nachricht 7 von 10
RDAOU
@spds.desk8
Unload or Switch off any CAD elements ...
No further guesses here. You are welcome to attach the model for a closer look. One cannot tell much from those images
Nachricht 8 von 10
spds.desk8
removed all cad links from projects and closed the file . After reopening , 3d view changed.
Nachricht 9 von 10
RDAOU
@spds.desk8
Looks better already..no?
Now Join geometry to get rid of the bleeding edges
Nachricht 10 von 10
syman2000
I would first check the eye and target elevation and see if you have huge value. Then in the view cube, you click on the isometric edge and it will reset the eye and target value.
