AnzeigenĀ Ā nurĀ  | Stattdessen suchen nachĀ
Meintest du:Ā
Need to Delete Dimension style
7 ANTWORTEN 7
Nachricht 1 von 8
1481 Aufrufe, 7 Antworten
I have bring some dimensions style from the one project to another project but unfortunately due to project protocols i don't need those dimensions style, now i am unable to delete the that single dimension style from our project.
Please suggest & advise for same.
Beschriftungen (1)
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: Anonymous
Nachricht 3 von 8
timlove
Use "Purge Unused" and select what types you do not want.  This is typical for system families.  You will always need at least one type left.
Nachricht 4 von 8
timlove
got to love when it doesn't refresh but posts anyhow
Nachricht 5 von 8
als Antwort auf: timlove
yes, you are right, i have to keep at least one dimension style but the unused one can't able to see in purge tab, even i have deleted all the dimension belongs to that style.
Nachricht 6 von 8
als Antwort auf: barthbradley
thanks for suggestion
Nachricht 7 von 8
ennujozlagam
Dimensions in legends (and drafting views nor sure about this but you can try) will not be selected in purging so need to go through these? thanks
Nachricht 8 von 8
willkperkins
Any advice for when the "purge unused" list doesn't include all the types?
I've tried "select all instances"  then deleting and have been through the legends manually checking for stray dimensions.
Thanks!
In Foren verƶffentlichen
