Hi: I am an engineering student working on a project in Revit 2024. I have a curved stair that has railing. on full length A part of the stair is attached to a curved wall. So, I need that portion of railing removed. When I tried to cut the railing, it doesn't work. I can delete the full hand railing, but I need to delete only a section where the wall will be used as handrail support
Gelöst! Gehe zur Lösung
Gelöst von Smunir30. Gehe zur Lösung
You should be able to edit and split and delete. Post the file.
Just to be clear, I'm talking about Railing, not Stairs. You are too.; right?
Yes, need part of the railing removed where I will use the curve was instead. Please see attached
I have no issue spitting and deleting portions from your Railing Sketch. Do you have a screenshot showing what portion you want removed?
Need to remove the stair rail that is attached to curve wall. What tool did you use?
This?
Edit Railing and use the Spit Tool to split the Sketch Line and then Delete the Sketch Line. Then Finish and close out of Editing Mode.
@Smunir30 wrote:Got it. Edit railing and then cut
What was the solution? It certainly wasn't "edit railing and then cut". The only solution is "Edit Railing and use the Spit Tool to split the Sketch Line and then Delete the Sketch Line. Then Finish and close out of Editing Mode".
