Need suggestion in making this family in revit
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
jaiganesh.venkatesan
602 Aufrufe, 5 Antworten
Suggest which template will suit for this and give me a idea to work on the in revit family.
Beschriftungen (4)
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: jaiganesh.venkatesan
Generic model adaptive.
Nachricht 3 von 6
Kind of hard to advise you properly without knowing what is it, how it is going to be used, what method are you using to model it, etc.
I mean, I could suggest modeling it directly in the Project using a spiral Stair Type that only has one stringer and no treads or risers.  Catch my drift?
Nachricht 4 von 6
Nachricht 5 von 6
a simple way could be by using Mass ...as follows:
Constantin Stroescu
Nachricht 6 von 6
Thankyou, its a kind of theming str.. behind that I going to make a lighting layer as same as the theming in  revit family. Problem is the theming is in CAD format. The str.. which i going to make is to be in rfa. format and to should be adjustable in future.
