NEED HELP WITH REVIT ISSUE
2 ANTWORTEN 2
Nachricht 1 von 3
253 Aufrufe, 2 Antworten
im working on windows 10 and and revit 2017. Every time i try to open up Revit, it says autodesk has stopped working and i have to close the program...Any help would be greatly appriciated (ps I already uninstalled and reinstalled the software)
2 ANTWORTEN 2
Nachricht 2 von 3
ennujozlagam
als Antwort auf: Anonymous
hello, try to install latest updates from autodesk and updates your graphics card driver and see if helps. thanks
Nachricht 3 von 3
Viveka_CD
Hi @Anonymous
The cause of this error is due to a Windows Error Reporting system that has determined that the application is no longer responding and presents the alert.Please, follow these steps and retest the behavior afterwards:
  1. Close all Revit sessions on your computer
  2. Go to Windows > Start > Search field and type %temp%
  3. Hit Enter
  4. Clear all instances in the Windows Temp folder
  5. Skip all instances Windows reports to be in use
If clearing the Temp folder does not clear the issue, there are two more approaches to track down the cause of this error:
Check for the latest updates from the Autodesk desktop app.
Let me know if you were bale to resolve your issue and if you have additional questions.
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome.
