Need Help with Massing
nikitesh95
nikitesh95
I am learning Revit and Currently Drafting 'The Theme Building, LAX Airport. Most difficult i found is The Arch of structure, Please help me this.
aleksandr.b
You can try to combine it by sweeping profile along a path
Best regards, Aleksandr Barsukov.
Show us a view of what you're trying to do.
You mean you are going to cut your teeth in Revit by modeling this structure???
You know it's over 60 years old, don't you?  If I remember correctly, I believe the TV Show "Lost in Space" was the original inspiration for it. Groovy; huh?
you are probably better of making a structure like this is rhino/
I don't do Rhino, but I could model this structure in Revit. I'm just saying that it is quite an ambitious challenge for a beginner.
Here's a quickie that captures the essence of the LAX construct.  Arches were created by cutting the OOTB solid dome mass geometry ("Dome.rfa") with a bunch of void geometries.   Subtractive vs.Additive modeling.
nikitesh95
Thanks for suggesting, I got solution, I drew it using extrude command
