Hello I have been working on this for days. I am trying to create a family that has two annotation family's nested in the main family. When brought into the project I would like for it to be visible depending on the sheet or view name or even using a schedule to change in between the two annotations showing depending on the view. For example Family model has Annotation1 and Annotation2 with visibility parameters as nested family's, so when I bring it in to my project I could like it to show annotation1 on floor plan and then annotation2 to show up on all other views except floor plan. Would these be possible to achieve?
Gelöst! Gehe zur Lösung
Gelöst von SteveKStafford. Gehe zur Lösung
There is nothing built into Revit natively that will make an annotation family react or respond to the view it is visible in. What does this family look like or intend to do?
Steve Stafford
Thank you for your reply. I have attached the family I made. So what I was planning is for egress annotation to show up on the egress plan/view/sheet only and for non egress annotation to show up on all other plans/views/sheets. If there is a work around maybe with a schedule or other methods. Thank you for your time and help.
Don't embed the annotation in the family, use a tag and different types for each kind of view. Leave some part of the fire extinguisher visible so there is something to see and tag in plans. Right now your family doesn't show anything in 3D or any view besides the annotation.
Steve Stafford
Thank you for the help. I understand what you meant and gave it a try and it work thank you!
