Is it possible to work on a Revit project in the following work flow:
1. Local Setup, Project Creation
a. Create a building as a the Architec >> create floor plans
b. Adjust the elevation hieghts of the facility
c. remove any sheets provided from the template used to create teh project
2. Setup the Teamwork Environment
a. Post the basic building shell on the network
b. Open and re-save the file as a central file
3a. Trade Discipline Work Flow, LINKED
a. Create a new project from a Trade Template
b. LINK the central file into the project brings floor plan and all other trade system with it
c. Add a new trade discipline system to the local project model
d. Create trade Discipline Sheets
e. Push the new trade system into the central project file
f. push the trade sheets into the central file
g. do all this but NEVER allowed to modify the central building floorplan or other discpline system
3b. Trade Discipline Work Flow, LOCAL INSTANCE
a. Open the central file as a local instance, brings floor plan and all other trade system with it
b. Add new trade system to the model
c. Create Trade Discipline Sheets
e. Push the Trade system into the central project
g. do all this but NEVER allowed to modify the central building floorplan or oher trade systems
The goal is to be able to get each trade system into the central file and push system updates into the central file to allow clash detection operations on the central file BUT mantain the systems and trade sheets in a separate trade model for each discipline.
I should also mention I would like to be able to link other discipline systems into a local disciple trade project WITHOUT the linked model sheets. Is this possible?
Which is the preferred method? And or do I need to course correct a bit?
Thanks in Advance
Tim C.
