Need help with a paremetric family
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
advandes
373 Aufrufe, 9 Antworten
Hello, I have created a family of a walk-in cooler and can't figure out how to add a parameter that will let me locate the door along one side. I would like an option to locate the door from one side of the cooler to either the center or edge of the door. I thought it was going to be easy, but I am struggling with it. Any help would be VERY much appreciated. Thanks, Aaron I have attached the family for your use.
AAG
Advance Design
9 ANTWORTEN 9
Nachricht 2 von 10
L.Maas
als Antwort auf: advandes
Make the the job easier by splitting the task in 'segments'. I would make use of nested families. For example the door would be a good example to be created in a nested family. In the nested family you create the door with all the dimensions and ironmongery. In the host family you can position it properly.
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 10
Sahay_R
Aaron - here is the modified family.
When you have two reference planes that have the property Defines Origin, that will be your insertion point
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 4 von 10
advandes
als Antwort auf: Sahay_R
Rina, thanks for helping me out, but I do not see anything different with the family you attached. I must be missing something. Also, my client is using Revit 2016, so I can't use a later version family.
AAG
Advance Design
Nachricht 5 von 10
Sahay_R
Maybe that's because 2017 crashed!
Tested - insertion point is in the middle of the back wall.
Rina Sahay
Nachricht 6 von 10
advandes
Rina, I apologize if I am not getting your revised family, but I can not see how there is an option (parameter) to place the door at a specified distance. The 2016 version is good though... I need more help. Thanks.
AAG
Advance Design
Nachricht 7 von 10
Sahay_R
Door at a specified distance from? I am setting up a parameter for saetting it away from the side.
My apologies - I am on 2016 and 2017 at the same time. Hence the madness.
 You should be able to type in the distance from the side that the door needs to be placed at.
Rina Sahay
Nachricht 8 von 10
advandes
Rina, I need a parameter that will allow me to position the door along the wall at any given distance from either end of the wall.
AAG
Advance Design
Nachricht 9 von 10
Create the door as a separate face based family with a void then load it in
the cooler family. Create a Reference plane where the center of the door is
and lock the door to it. Provide a dimension from one edge of the cooler to
the ref plane and assign an instance parameter. Now load the cooler family
in your project and you will be able drag the door along the cooler wall.
Nachricht 10 von 10
