Need help making new parquet .pat file
Would anyone be able to help me create a .pat file for the flooring pattern in the image attached? The plank sizes are 1m x 25cm.
Try this.  It is based on Project Unit set to centimeter.
hugha
Certainly.
;        Written by HatchKit Professional
;        HatchKit Professional (c)1990-2016 Cadro Pty Ltd
;        www.hatchkit.com.au/
;-Date                                   : 14/01/2017
;-Time                                   : 13:03:19
;-HatchKit Version                       : 3.1.9.2674
;-HatchKit Output Filetype               : Revit with HatchKit Add-In
;%VERSION=3.0
;%UNITS=MM
*parquet
;%TYPE=MODEL
90,-250,0,1000,1000,1000,-1000
90,-500,0,1000,1000,1000,-1000
90,-750,0,1000,1000,1000,-1000
0,0,250,1000,1000,1000,-1000
0,0,500,1000,1000,1000,-1000
0,0,750,1000,1000,1000,-1000
0,0,0,0,1000
90,0,0,0,1000
Hope this helps,
Hugh Adamson
www.hatchkit.com.au
This worked perfectly. Thank you for your help.
