Need Help in printing i Revit
1 ANTWORT 1
Nachricht 1 von 2
246 Aufrufe, 1 Antwort
Please I have a deadline soon and I am quite stressed as far as I cant print pdf normally from Revit. It is really bad quality (deformed lines, some liens are missing also and are too thick) for autodesk.jpg
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
Hello!
The problem with the missing lines can be solved in the view you`re trying to print. Check if are not hidden elements (click on the lamp symbol below your view). The lines being to thick, probably ir cause of the bad zoom on the printed file. Try to check the options below:
1. First, you have to get a PDF printer. My suggestion is the DoPDF8 (available here);
2. After installing the printer, go to the printing settings on Revit and set the DoPDF 8 printer as your current printer;
3. At the Print Range field, choose the sheet you want (observe that you must know the real size of the sheet);
4. At the Settings field, click on the Setup button. Then, choose the real size of your sheet (A4, A3 etc) or choose the Custom Size option, set the zoom to 100% and the paper placement at the center;
4. Only if your choice on 4. was Custom Size, on the side of your printer's name, click on the Properties button. As you already told that you want a Custom Size, just move the dimensions to millimeters and enter the correct dimensions of your sheet. Pay atention at the orientation of the sheet. If the landscape orientations doesn't work, try the portrait;
5. You're all set. Just choose to print as seperated files and click on OK. The window will open is the DoPDF window. Choose the output location of your file and click again on OK.
If your problem has been solved, please click on Accept as Solution. Then others users can take benefit of it.
Felipe Góes
Autodesk Instructor
