On the sheet, I have double clicked the view and am on that not the sheet. I can dimension an object to another object but cannot dimension how far off the ground it is. I click on the object and then the ground, and when I click on the ground, the dimensioning tool goes away as if I had hit escape. I have tried with both aligned and linear tool and cannot get either to work. Any help/ advice on this error is more than welcome. Thanks
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
