Here i attached my revit file, and this is the autocad file which exported from, not i'm having several problems and i really need help:
1- columns are exported exploded i don't know why in spite of in the columns family i checked the box of (always export as geometry) and u can make sure if u checked the col. family
2- the wall layer which supposed to get yellow color in cad is not continuing around the columns as it must do, but it stops before columns and never surround it, and i'm also having some troubles of understanding the function of the (wall's common line) function, finally i can't get what i want in the cad file, i believe that there is something 'm not understanding well enough
3- each view in the revit is exported in a separate file, and this is very annoying to me as i have to merge them all in one file in the end or at least plans, elevation and section must be all each in one file ...
what can i do friends? please help
I am only going to help you with point 3.
When exporting, at the moment when the name of the file is requested, make sure to untick the tickbox shown on the JPG attached.
Also try clicking the box shown in the other image (preserve coincident lines) You had it unticked.
Good luck with the other issues.
