Can someone convert a terrain file made in Revit .rvt to Cinema 4d? How much would you charge and how quick can you do it? I think an .obj would be best, There are no materials in the file only a mesh.
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
Have you try opening Revit file in 3dsmax and then export it as OBJ.
Just upload the file.
you can check HERE and HERE and see if helps. thanks
export as ifc and then open in your C4D and see if helps. thanks
Here you go. I've converted the file into 3 different format - OBJ, DXF and IFC. See if those files work with the Cinema 4d.
Thank you so much . The obj file worked and i can get busy on this project. How can i repay you? You are the best!
Just mark this topic as solved.
