Navy lines in the model
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
724 Aufrufe, 6 Antworten
Hello guys.
Could someone find out what is going on here?
Lines on this part became blue. Only this curtain wall.
In 3d, elevations, plans....
It is about override or visibility problem..
Tags (1)
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
Check your object styles...someone probably changed them....more than likely someone that works with a black background.
Nachricht 3 von 7
Thanks for the reply.
I checked Visibility, object style. But other curtain walls are just black..
Only this part of the model line is blue.
You might see the difference.
Upper curtain wall has black line but the bottom one does not.
Nachricht 4 von 7
..."more than likely someone that works with a black background".  Good one, Sherlock.  I think you narrowed this list of suspects.  Betcha it's the "AutoCAD" guy!  Ha!
Nachricht 5 von 7
Try and copy the problem curtain wall out of the wall. This will remove (If any) graphic overrides that might be on the particular curtain wall.
The next thing to try would be uncut the curtain wall from the host wall, and then recut to see if it is revit freaking out.
You could also try and "Match properties" from a correct curtain wall to the incorrect curtain wall and see if it just some  properties that are the problem. Basically try and make a new curtain wall and see if does the same thing.
Nachricht 6 von 7
Is it created and demolished under the same phase by any chance?
Nachricht 7 von 7
als Antwort auf: ToanDN
ToanDN, yes I found out the navy color on the phasing->graphic overrides menu.
It was on temporary.
I just changed the object PHASE DOMOLISHED to None in Properties.
Many thanks!
