Navisworks to Revit 2016
1 ANTWORT 1
Nachricht 1 von 2
839 Aufrufe, 1 Antwort
Can any of the file types that can be exported from Navisworks be imported into Revit 2016?  If so can we control if it is a mesh or solids?  If so what is the recommended process?  Is there an add-in that can make it happen?
Some of the models that we need to work with are only available in NWD.  I need to get the geometry into Revit, and then be able to export an IFC that has everything in it.  Linked files usually don't make it into the IFC.  Linked models frequently cannot be exploded.
Most of this stems from a blend of Revit and Rhino files.
Thank You
Nardo
1 ANTWORT 1
Nachricht 2 von 2
Sahay_R
als Antwort auf: Anonymous
Not good news, I'm afraid.....
https://forums.autodesk.com/t5/navisworks-forum/import-nwd-or-nwc-into-revit/td-p/5658620
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
