Navisworks exporter glitch, can't select options
2 ANTWORTEN 2
Nachricht 1 von 3
isosa9APBT
209 Aufrufe, 2 Antworten
I been working with the Navisworks exporter for a while and I haven't had any issues until now. I installed everything as normal for Revit 2025, Navisworks 2025 and the exporting utility. I did notice that for the new utility there are two files, the regular installer and a file ending with .7z. I have never seen that extension before. When I try to export my file from Revit and I go to the options button I can only see the check boxes and the fill sections. I did the exact same installation on two different computers with the same outcome. Has anyone experienced this?
2 ANTWORTEN 2
Nachricht 2 von 3
vitorbortoncello
als Antwort auf: isosa9APBT
Install the Exporter 2025
https://www.autodesk.com/products/navisworks/3d-viewers?_ga=2.46138215.1128728288.1621788806-1177203...
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 3
isosa9APBT
als Antwort auf: vitorbortoncello
That's what I did, that's the only way I know of to even have the option to export.
