Navisworks export button has disappeared from REVIT 2016 ?
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
jsanders
2097 Aufrufe, 4 Antworten
I can't export to NWC when using Revit 2016. Is has literally disappeared. What can I do ?
Thank you for your answers.
__________________________________________________________________________
ヽ༼ຈل͜ຈ༽ノ Onward still he goes, Yet ne'er looks forward further than his nose ヽ༼ຈل͜ຈ༽ノ
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: jsanders
Hi @jsanders,
you need to install the NWC exporter tools before seeing it.
http://www.autodesk.it/products/navisworks/autodesk-navisworks-nwc-export-utility
You can find it here.
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Infraworks Ambassador
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button
Nachricht 3 von 5
als Antwort auf: Anonymous
I did, but for some reason its not showing on the external tools under addins
Nachricht 4 von 5
DarrenP
what version of the exporters are you installing?
DarrenP
Nachricht 5 von 5
als Antwort auf: DarrenP
oh no sorry, i had installed the plugin of 2017 yet my revit is 2018. so i
had to install the 2018 plugin and it worked well. Thank you
