Nauman.BIMologist help - SLOG Check User-Build-Session.bat
2 ANTWORTEN 2
Nachricht 1 von 3
mdhutchinson
278 Aufrufe, 2 Antworten
Is it ok to run this/these batch on a live SLOG file whose Central File is currently being accessed?
2 ANTWORTEN 2
Nachricht 2 von 3
Matt__W
als Antwort auf: mdhutchinson
@mdhutchinson when in doubt, make a copy and run it on that but you should be okay to run it on live .SLOG files. It reads the file and outputs info to a _rpt.txt file. @BIMologist_ can get into it more if needed.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Nachricht 3 von 3
mdhutchinson
als Antwort auf: Matt__W
I added to Nauman’s batch to copy the SLOG to another location and process it there.
works good at initial tests.
thanks!
